General Motorcycles only
Old 02-Mar-2006, 17:37   #1
Carbon749's Avatar
Mood: I own a flame thrower
Brembo radial master Cyl\' - what size for road use ?
Hi,
As the title says .... what size Brembo radial master cylinder would you go for or already have fitted ?
19 x 18
0r
19 x 20
Have seen a few bikes with 19x20 fitted, but, also heard some one say that it's too much like a "trigger" and that 19x18 would be better suited to road use.
Anyone know what the standard size is on 749 / 999 ?
[Edited on 2-3-2006 by Carbon749]
Old 02-Mar-2006, 18:48   #2
FiscusFish's Avatar
Am I suffering from deja vu or was this asked and answered last week by Nelly amongst other...?
I think I need to lie down...
Old 02-Mar-2006, 19:11   #3
Yes, you are suffering from Deja Vu...
The answer is DEJA HERE
Old 02-Mar-2006, 19:33   #4
Carbon749's Avatar
I'll get my coat and turn the light out
Old 02-Mar-2006, 19:46   #5
well almost........................ the stock lever on the 999/749 etc is 18mm bore and x19 ratio.
The "race" radial is 19mm bore so will shift a little more fluid. A x18 will probably feel about the same as you have now. The x20 will decrease the lever travel a little more than you have now.
Both will offer a small increase in "braking power" but nothing like the improvements on the 748/998 range as they only used a 16mm master cylinder
Now get ya coat
Old 02-Mar-2006, 20:07   #6
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
19X18 on the 888 and works reallly well..best compromise (ive ridden with the 19x20 and it lacks 'feel' compared to the 18..
Nat
