Old 03-Mar-2006, 13:35   #1
GlennG GlennG is offline
Mood: accepting the inevitable
Embarrassing 620 Sport Question ...
Well I feel a right numpty asking this but how do you get the front wheel out .... no laughing at the back now
The bike's jacked up with the front wheel spindle out but the wheel cant be removed because the calipers are in the way, so I removed the caliper bolts and tried to slide the calipers off the discs, but the calipers could not be taken off the disc because the back of the calipers touch the wheel rim. I even took the front guard off to try and rotate the fork lowers slightly to give eveything abit more clearance, but because the calipers still sit on the discs that didn't work either.
Do I have to take the discs (with calipers still attached) off the wheel to allow the wheel to be removed, surely not?
Am I missing something? (I know I'm setting myself up here :P )
Can other 620SS owners remove their calipers from the discs easily enough to allow the front wheel out?
Old 03-Mar-2006, 13:40   #2
t5mission t5mission is offline
Mood: Will my DD fit in a Fiat Scudo?
Twist the caliper to the side this will open the pads slightly and allow you to get them out.
Old 03-Mar-2006, 13:40   #3
domski's Avatar
The calipers are a tight ish fit, but you should be able to wiggle them off.
Try pushing the pads back in a bit by pushing the caliper against the disk, that may give you a little bit of room to ease the caliper off.
You always need to take the calipers off to remove the front wheel.
Old 03-Mar-2006, 13:42   #4
Stop trying to take credit for my greatness Domski....
Old 03-Mar-2006, 13:55   #5
OK thanks for info I'll try that later
Old 03-Mar-2006, 14:12   #6
As you slide the calipers off of the disk, you can angle them and as a result push the pads (pistons) back in the calipers. This will give you enough room to remove the calipers.
It is a tight fit though and you may want to put some tape on your rims to prevent scratching them with the calipers when you're removing them.
When re-installing them, you will probably need to use a screwdriver to push the pads back to give you the clearance required.
Care and patience and you'll be fine.
Tim
Old 03-Mar-2006, 14:27   #7
Founder Member
Paul James's Avatar
Just be careful that you don't push the pads back too far if your brake master cylinder reservoir is full of fluid !!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:10.
