Old 03-Mar-2006, 19:06   #1
theduke900ss theduke900ss is offline
900ss sump plug
Hi can any one help tried to shift my sump plug but the allen key hole in the plug has rounded corners and I cant shift it.
Old 03-Mar-2006, 19:12   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
When I bought my 748SP many years ago it was suffering the same (just had a 600 mile service done by Daytona in Islington!!)....anyway, I got and impact driver and literally chisel a slot in the sump plug with it before I could turn it out. In such a situation I would advise you to go to a dealer or preferably some decent engineering workshop that could do it for you.
Old 03-Mar-2006, 19:53   #3
boski69 boski69 is offline
boski69's Avatar
Mood: Here comes the summer!!!!!!!!!!!!!!!!!!!
Had my 900SS for over 6 years now. The 1st time I tried to drain the oil I met the same problem as you. I got round it by removing the gauze filter on the right hand side of the engine low down, and then removing the oil filter. this drains most if not all of the old oil. Replace the 2 items and refill with fresh oil. Cheers, Bri.
Old 04-Mar-2006, 02:54   #4
edwyun edwyun is offline
Note:
The sump plug's socket opening is tapered so it's easy to think the socket is fully in place when it's not. Then when you try to loosen it or torque it, it strips the soft plug. Happens alot.
use the methods already posted, and replace with a new OEM plug, or an aftermrket one.
Old 04-Mar-2006, 18:28   #5
Use any old chisel and whack it out - worked for me with the DD bike.
I've replaced it with a fancy ally one to lockwire, but I'd recommend you replace it with the same to save rounding it out each time.
Old 04-Mar-2006, 19:33   #6
Thanks for your help
Hi thanks to everybody that replied for your help think i will drain it out through the filter for now and get it done later just got to fit an evolution clutch slave cylinder then i am back on the road.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:01.
