Old 05-Mar-2006, 20:05   #1
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
SS swing-arms
Did the 900ssie come with an alloy swing-arm of a steel one? Or was it a case of a mixture depending whether or not the factory had the right parts. Also if it came with an alloy item was the rear caliper mounted topside or bottom-side?
Of my two 800's - one came with an alloy arm, one with a steel. Both had calipers that were topside.
I am hunting for another alloy arm but, they're rarer than rocking horse turds.
Old 05-Mar-2006, 22:12   #2
ali ali is offline
ali's Avatar
Mood: Damp
I think all uk 900s came with alloy s/arms. The US had a version called the Sport which had a steel swinger and non-adjustable forks, but I've only seen a couple in the uk.
The caliper was originally located above, fixed on that plate. About 96/97 they went under-slung and floating to compensate for swingarm movement.
Alloy swingers come up occaisionally, worth about £50-80, but watch out for cracks around the shock mount.
I could have changed the steel one on the race bike, but I really don't believe it would make the blindest bit of difference!
Old 05-Mar-2006, 22:57   #3
Thanks Ali - I'm working on the basis that an alloy one should represent lower unsprung weight but, guess I should weigh them both to dispel any myths!
Old 05-Mar-2006, 22:59   #4
So you didn't weigh them both to see what the difference was then?
Old 05-Mar-2006, 23:33   #5
I know the SS is different in construction but on the late monsters the alloy one is about 1.5kg lighter when made from ally
I'd reckon you'd save the same on the SS................
Old 05-Mar-2006, 23:36   #6
Thanks Nelly - that's worth having when it comes to unsprung weight. Now I need to find one!
Old 05-Mar-2006, 23:40   #7
Slightly more nelly, but yeah it's a worthwhile saving
Old 05-Mar-2006, 23:56   #8
You can save even more antonye, by drilling several large holes in the aloy arm itself ........................... go on try it
Old 05-Mar-2006, 23:59   #9
I knew I'd find a use for my Black & Decker eventually.........
Old 06-Mar-2006, 00:13   #10
ali ali is offline
ali's Avatar
Mood: Damp
The difference in unsprung weight has more effect the more powerful the bike is (in the case of the rear) as it's primary benefit is to allow the suspension to react faster with less extension, therefore helping prevent highsides. Normally I'd say the little 620 doesn't have enough go to do much in the way of highsides, but I managed to highside a 675 last year so I'd have to agree, probably worth doing!
If things get really close this year I might invest in one, but I doubt I'll get to a situation where 2kg is going to make a difference to anything....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:09.
