Old 05-Mar-2006, 20:55   #1
paynep's Avatar
Mood: Wet wet wet
It runs!......but
Hi y'all,
I think Spain was just far enough away to miss last weeks fun on the 'board
Also I never knew that Jerez was Spanish for sherry, but hey....
Anyhow, back in the garage I finished off the wiring on the 620SS and voila, it runs.
Only thing is once it gets warm the idle is up at 2000rpm, even with the stop wound right back. I've sprayed WD40 around the manifolds and injectors but can't find any leaks. Everything is pretty much as it came off the monster, apart from being kicked around in a big box for a couple of months....any ideas or will I have to wait until I can get it to a Mathesis tester??
Old 05-Mar-2006, 21:01   #2
CK CK is offline
air bleed valves on the side of the throttle body Paul? (brass screw at the back end of the throttle body) might have moved?
or try the throttle position sensor, make sure its not loose.
Obviously you'll have checked the fast idle mech isnt jammed on too?
Something to pass away the next 2 mins for you mate.
Or have you already checked these out?
Alan
Old 05-Mar-2006, 21:13   #3
paynep's Avatar
Mood: Wet wet wet
Originally posted by CK
air bleed valves on the side of the throttle body Paul? (brass screw at the back end of the throttle body) might have moved? still crud covered and tight
or try the throttle position sensor, make sure its not loose. nope
Obviously you'll have checked the fast idle mech isnt jammed on too? - only happens when it gets warm
Alan
Have given up for the night so I can get prepared for a weeks backlog at work...
Cheers, Paul
Old 05-Mar-2006, 22:35   #4
Ducati Dealer
wilf's Avatar
good luck Paul
see you sometime mid week then
may be in my interest to get this one running well.....
Old 05-Mar-2006, 23:01   #5
Can't offer any help as ours is now running too
Good luck though!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:39.
