Old 26-Jan-2014, 17:22
Mykie916's Avatar
Mykie916 Mykie916 is offline
Bikes: 98 916, 2006 Blade, DD Class B #20
Hi
Hi everyone, should be racing with you this year (be nice )
Quick technical question, before I fabricate the bracket below from ally, is my template exactly what is required to bolt down front of tank ? I've done it this way so I can still lift tank after undoing 1 bolt
Booking ACU test for 2nd march, all being well looking forward to meeting you all,
Mykal
Old 26-Jan-2014, 18:06
Looks good to me
Old 26-Jan-2014, 20:12
"Invalid Attachment specified. If you followed a valid link,"
Old 26-Jan-2014, 22:25
Mykie916's Avatar
Sorted
Old 28-Jan-2014, 23:40
badgerpilot's Avatar
Bikes: Badger DD A #50, Multistrada 1200s, Aprilia Tuono 1100rr
Looks pretty much just how I've done it.
Welcome to the loony bin of racing!
Scott #50
Old 31-Jan-2014, 00:00
Mykie916's Avatar
Thankyou, looking forward to meeting up
Old 31-Jan-2014, 00:01
Mykie916's Avatar
Old 31-Jan-2014, 12:53
Mykie we need to sort you out a race number, I will dig out my list of available numbers and email it to the address you sent me
  #9
Old 01-Feb-2014, 18:36
Mykie916's Avatar
Ok, where do the actual numbers come from, I.e do I go and get them and are they a certain size font etc ? Cheers Myk
  #10
Old 02-Feb-2014, 15:05
milesaway's Avatar
milesaway milesaway is offline
Bikes: 900ss 600ss xr400
once you know what your numbers will be u can get from ebay or similar or make some any simple font
class b black number yellow background/ class a black on white
acu says;
3. Each machine must display two side number plates. The numbers must be clearly visible to the
public and marshals on both sides of the machine.
5. The figures must be clearly legible and like the background must be painted in matt colours as
described below to avoid refl ection in sunlight.
6. The minimum dimensions of front numbers are:
Background 285mm by 235mm
Height of figure 140mm
Width of figure 80mm
Width of stroke 25mm
Space between two figures 15mm
7. The minimum dimensions of side numbers are:
Background 260mm by 220mm
Height of figure 120mm
Width of figure 70mm
Space between 2 figures 15mm
8. A space of at least 5cm must be left free around all number plates in which no advertising may
appear.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:34.
