Old 07-Mar-2006, 14:46   #1
istanbulian istanbulian is offline
Mood: Mellow but missing Turkiye
Replacement oil cooler source ?
Does anyone know of a decent source for used oil coolers ? The stones and road debris out here have totally wrecked my original oil cooler to the extent taht my oil is overheating and losing pressure.
It looks beyond repair;as a result I need to replace it and a used rather than new would be ideal !
Ian
Istanbul & St. Albans
[Edited on 7-3-2006 by istanbulian]
Old 07-Mar-2006, 14:53   #2
Ebay would be my first try although there is nothing on the UK site at the moment.
Old 08-Mar-2006, 09:43   #3
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
Try Jim at Bikenders - he's a star and always has parts I need, no matter how obscure. Prices are good.
01708 455530
Spin
Old 08-Mar-2006, 16:31   #4
james81273 james81273 is offline
james81273's Avatar
Mood: twitching
rebuild or buy new?
have you tried repairing it for example Serck Marston to rebuild the unit. Not sure how expensive but they did my radiator on my winter hack (r6) for £80 a little while ago?
this is dependant where you are in the world UK should be ok anywhere else~???
Old 08-Mar-2006, 16:37   #5
Thanks for the responses.
I will try to get it repaired locally in Istanbul first then; normally they are pretty good here for repairs but the place I took it to first in Çorlu ( 100km west of Istanbul!) just cleaned it and snt it back as it was
Otherwise next time I am back in the UK it will get replaced !
Old 08-Mar-2006, 18:43   #6
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Does it leak? If not then what is the problem? As long as the cores are ok then it's ok to use albeit a bit scruffy. I just protect it with a mesh and straighten any bent fins using some tweezers - a bit fiddly and time consuming but, not difficult.
Old 09-Mar-2006, 09:39   #7
No leaks; just not working very well resulting in overheating of the oil and loss of pressure.
We have had a go a strightening the fins so perhaps I should just try again and see if it still overheats or not before getting it re-cored.
