Old 02-Feb-2014, 22:22   #1
mattslade mattslade is offline
fuel pump priming
I tried to start bike the other day with no joy i thought i was pushing my luck as voltage a bit low afterwards eobd on showng 12.2 13.2 which normally means fuel pump relay but I've dropped the headlight relay in supposedly the same relay with no joy. is there a secret inline fuse somewhere? I've checked the 6 obvious ones. If not what should i try next.
Old 02-Feb-2014, 23:18   #2
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
Fuses - one set by the headlight, two further ones on the battery box. The ones on the battery box are for the ECU (3 amp) and Injection relay (20 amp).
The injection relay fuse is the lower one.
Did you charge the battery?
The ECU is voltage dependent and if it is too low you won't start the bike.
Have you done the secondary earth mod? Worth doing with 749/999's as they get older.
Old 03-Feb-2014, 00:16   #3
Charged the battery I've got 12.2 I've started it with as low as 11.7 and i think I've heard the pump prime with lower than that.
Old 03-Feb-2014, 19:55   #4
DSC Member simonducati simonducati is offline
Bikes: Had 748,749, 848 and now a 1199 Panigale
simonducati's Avatar
Mood: Living the dream.
What is the secondary mod?
Old 03-Feb-2014, 20:23   #5
spurs spurs is offline
Bikes: 999s and 955i Daytona
Its either upgrading the battery cables which are available from a few sources , you could look on ebay .
Or putting an extra earth wire from the battery earth to a good clean point on the engine e.g . one of the engine case screws . Which is what i have done - the starter seems to crank the engine over a little faster with this on .
Old 03-Feb-2014, 20:53   #6
cool, I will look in to upgrading mine as I don't want any issues in the future.
Old 04-Feb-2014, 00:15   #7
What exactly do i need to put into ebay to locate what i need?
Old 04-Feb-2014, 11:23   #8
Have you checked the resistance in the sensor by the clutch assembly?
I had a problem with that when I had a 748 and it just wouldn't start.
Old 04-Feb-2014, 19:04   #9
chrisw's Avatar
To do the secondary earth mod read this http://ducatiforum.co.uk/f92/749s-wont-start-12766/
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:09.
