Old 11-Mar-2006, 19:43   #1
fraggle fraggle is offline
Mood: The 996r is back on the road!!!
916 Strada - Exhaust & Chip Advise Please
Hi,
Just finalising a deal for a 95 916 Strada, would like to put some nice exhausts on, Termi's preferably, which size are the best, and with what chip??.....any advice gladly received.
Old 11-Mar-2006, 22:53   #2
45mm will be just fine if it's the noise and a small performance gain you need. If you plan on working the motor a bit more, then go for a 50mm half system.
The 45's will be the cheapest option to.
A chip from JHP is as good as any and not too expensive at around £35.
Once it's all fitted up, get it set up properly to make sure everything is just right. The chips are not a simple plug'n'play............
Old 12-Mar-2006, 10:32   #3
Thanks for that Nelly
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:19.
