Old 12-Mar-2006, 17:55   #1
multi600 multi600 is offline
multi600's Avatar
Mood: Hopefull
Filler cap removal
I am in trying to remove the filler cap to paint the tank on my 600ss DD bike. I have removed the 8 alan head grub screws in the alloy plate at which point I thought it would come out but no I have tried to twist ( both ways) and pull but no joy. Do I need to do something else to get it out.
Mike
Old 12-Mar-2006, 18:22   #2
aka.eric aka.eric is offline
They are damm tight,had the same problem with 888.Asked the same question,slide hammers mentioned!.Eventually it pulled out,reassemble with a bit of rubber grease on O ring.
Old 12-Mar-2006, 18:27   #3
multi600's Avatar
Mood: Hopefull
Cheers for that.
Mike
Old 12-Mar-2006, 18:44   #4
Remove the grub screws completely and spray some wd40 in the holes. Use a hammer shaft in the filler and "work" it to help the wd move around the o-ring.
don't lever too hard else you'll dent the tank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:09.
