Old 14-Mar-2006, 12:01   #1
GlennG GlennG is offline
Mood: accepting the inevitable
Clutch Cover
I've been servicing my bike and alls going well until I came to take the clutch cover off last night, I've removed the 10 allen bolts and used a rubber mallet on the top, bottom and sides but it wont budge.
I dont need a puller for this side case do I?
Old 14-Mar-2006, 12:03   #2
Nope
Old 14-Mar-2006, 12:27   #3
Hmmmmm....
I wondered if there were more screws - but Haynes also says there are only 10 and that a soft faced mallet is all that should be needed to 'tap' around and break any gasket seal.
F.
Old 14-Mar-2006, 12:31   #4
khushy khushy is offline
khushy's Avatar
Are you taking the clutch cover off or are you taking the clutch housing off??
Clutch cover = about 6 bots
Clutch housing = about 15 bolts + sealer etc
If you are servicing your bike, I would say that you need nly to take the clutch cover off to get to the clutch - why do you need to take the housing off?
Khushy
Old 14-Mar-2006, 13:05   #5
On my 620 Sport I can only see the one cover/housing (10 bolts) to remove, there does appear to be some sealant around the edges, so it could be just this that I need to overcome but I wanted to check before I contnue tapping the housing with the mallet.
I need to get into the clutch to check the plates are okay, as Baines said the clutch noise was abit louder/unusual than normal, and could well be broken steel plates which they saw a few times last year.
Old 14-Mar-2006, 14:35   #6
That'll be all the extra power from the high-comp big bore kits...
Old 14-Mar-2006, 15:00   #7
khushy's Avatar
if you only want to check the plates - surely you only need to take off the clutch cover and NOT the housing???
khushy
Old 14-Mar-2006, 15:12   #8
On some of the wet clutches they are the one and same thing. Depends on model and year, tbh.
Old 14-Mar-2006, 15:20   #9
khushy
Its a wet clutch on the 620s, which is not the same as the 996 type - there is no 6 bolt cover that can be removed.
Glen - if you've checked that all the bolts are out around the casing, it should come off relatively easily.
Bigger hammer !!!! ????
Tim
Old 14-Mar-2006, 16:31   #10
khushy's Avatar
ooooops - thanks Tim
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:36.
