Old 14-Mar-2006, 20:51   #1
Murray Mint's Avatar
Drilled oil filler and drain plug
Hi guys looking for a suitable drilled oil filler and drain plugfor my 600 ss, where do I get one from? Also I still desperatly need the 2 into 1 section of the exhaust system, the bit the joins the front and rear header pipes to the exhaust can. HELP PLEASE.
Murray Mint
Old 14-Mar-2006, 22:28   #2
Scooter916's Avatar
Mood: Hmmm Conference season
Murray I thought you were sorted for the pipe??
I have one that i could bring to caddy for you to borrow if you wish.
As for the plugs drill your own they are made from cheese
Glyn
Old 14-Mar-2006, 22:35   #3
CK CK is offline
Murray, if you dont have time, Alan always brings drills & lockwire etc, and says he can help you out on the Sat if needed.
Old 15-Mar-2006, 01:59   #4
http://www.moto2.co.uk/
Tenner each, all Ducati ones are the same size.
Old 15-Mar-2006, 09:13   #5
t5mission t5mission is offline
Mood: Will my DD fit in a Fiat Scudo?
For the oil filter just put a jubilee clip rouind it and lock wire that.
Old 15-Mar-2006, 09:21   #6
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
you can bring me your drain plug, I'll drill it for you. I've done mine and it's not leaking yet
Old 15-Mar-2006, 09:56   #7
Scooter916's Avatar
Originally posted by Tonio600
yyet
Tonio forever the optimist
Old 15-Mar-2006, 10:18   #8
For the oil filter, use K&N.
These come with a pre-drilled nut on the end to make it easy to remove and lockwire. Not much more expensive than a standard filter.
Old 15-Mar-2006, 11:16   #9
Tonio600's Avatar
How much does a K&N oil filter cost?
Old 15-Mar-2006, 11:47   #10
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=7944491361
I only paid £15 when I bought three, so this guys is obviously making quite a bit of money at those prices!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:17.
