Old 16-Mar-2006, 00:02   #1
alan_db alan_db is offline
S*** Night - Advice please
Decided to take the 888 out for a little jaunt tonight and after about 5 miles I pulled up at a set of lights and it just died.
Bike turns over and fires but cuts out immediately once it starts. Any ideas.........?
Have had to push bike to a mates and leave it there.
PS - its the first time bike has run in about a month but its been away in garage under covers hooked up to a optimate.
To make matters worse when I eventually got home and locked up garage I managed to break the bloody garage door!!!!
Old 16-Mar-2006, 00:15   #2
Sounds like Fuel to me too - a mate had the same prob with his 900 monster last week. Would fire, then nowt. Fixed now, just refilled the carbs with fuel.
Old 16-Mar-2006, 00:25   #3
Old fuel was one of my thoughts too although its not been in the bike for long.
Suppose the cold / colder / less cold weather up here could be fouling the fuel up quicker than norm.
Once i get bike back home tomorrow I'll have a go at carbs and hopefully that'll sort it
Thanks for replies
Alan...
Old 16-Mar-2006, 01:06   #4
You could have a go at the carbs...if you can find them, but you'll have more joy looking for the fuel injection.
It could be dodgy fuel, but if you did 5 miles before the thing died it's more likely to be something silly like a trapped breather pipe. If the breather pipe is blocked or trapped somewhere then the tank will gradually build up more vacuum until the fuel pump won't be able to suck any more fuel out. Try opening the filler cap, if there's a big "phhhhhhht" of air when you lift it, that might be your problem.
Shouldn't think it's electrics otherwise it wouldn't fire then die - but you never know, could be a sensor connector or relay that's only just making contact and breaks contact with the vibes from the engine.
Sounds more like fuel starvation to me though
[Edited on 16-3-2006 by Jools]
Old 16-Mar-2006, 07:58   #5
My old 851 had the same symptoms,cut out at a level crossing,...then would only run for a few seconds.
It was a blocked fuel filter.
Old 16-Mar-2006, 09:53   #6
Jasper Jasper is offline
Jasper's Avatar
Definately fuel.As stated,check the breather on the tank and that both fuel lines are not trapped where they leave the tank.
Old 16-Mar-2006, 10:17   #7
t5mission t5mission is offline
Mood: Will my DD fit in a Fiat Scudo?
does the 888 have a fuel pump?
Old 16-Mar-2006, 10:33   #8
851neil 851neil is offline
Mood: need a bike...
yup - the 851 and 888 have a fuel pump mounted in the fuel tank, along with filter and some with de-gasser.
Old 16-Mar-2006, 11:07   #9
Thanks guys, course the 888 has fuel injection. Just went down school of thought like my old 750ss which had similar in winter, carb icing. It need drained and cleaned out occasionally.
Will check breather, hoses and filter later today.
Alan...
Old 16-Mar-2006, 11:11   #10
It will do if its fuel injected.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:47.
