General Motorcycles only
Old 16-Mar-2006, 14:48
david.hicks's Avatar
david.hicks david.hicks is offline
Rear Paddock Stand Handle?
Can anyone tell me the point of the 'removable handle with rubber grip' on this kind of rear paddock stand?
Old 16-Mar-2006, 15:05
itexuk's Avatar
itexuk itexuk is offline
Mood: Great
So that you can stop the rear wheel turning when on stand.
Old 16-Mar-2006, 15:43
rcgbob44's Avatar
Der!!!!!!
Old 16-Mar-2006, 16:36
m1keyp m1keyp is offline
If you use one then make sure that it doesn't "lock" the wheel by using the valve, you can probably guess the rest........................................
Old 19-Mar-2006, 00:46
greenmachine greenmachine is offline
Mood: Flatulent
The pic doesn't show the stand in it's full details as there seems to be something going on which i can't make out clearly.
On the face of it the grip is about as useful as a rubber nail.
On a positive note i'd estimate that the handle weighs approximately 2kg and at the current rate of £70 per tonne for waste steel/iron you should comfortably recoup a grand total of approximately 14pence for the handle at your local scrap merchant.
Spend your hard earned winnings wisely - or but a decent Micron stand.
Old 19-Mar-2006, 02:31
MARTIN H's Avatar
MARTIN H MARTIN H is offline
I think the idea of the rubber grip is to prevent damage to your wheel when you are putting 160 odd or whatever Nm force through it when fitting / removing the nut? That said you dont need it if you have another person to hold the back brake on!
Old 19-Mar-2006, 18:26
doogalman's Avatar
I have an FG version of this stand.. It has been so usefull. The wheel lock idea is great. Never had any grief and would not see any point in buying one without.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:31.
