Old 19-Mar-2006, 10:17   #1
flanagaj flanagaj is offline
Chain split links
I need to replace my chain and I was wondering what people think about split links. Do any of you guys use them ?
Old 19-Mar-2006, 10:56   #2
Dave G Dave G is offline
Dave G's Avatar
Thats a definite NO!
You'll break it!, superbikes make too much power for a split link, use one in an emergency only and then take it easy.
More appropriate for low power bikes
Old 19-Mar-2006, 10:56   #3
Totto Totto is offline
What you mean by split link , C type or SOFT link , most peeps use a SOFT link that needs a chain rivet tool , where are you there are plenty of tools about if you need a lend of one
I would not use a C type link only a Soft link , i have a chain tool if you are near Northern Ireland and want to borrow it
[Edited on 19-3-2006 by Totto]
Old 19-Mar-2006, 11:34   #4
That's very interesting. Someone I know recommended replacing the chain and using a split link to enable it to be easily taken on / off.
Thanks for the offer of the chain tool, but I live down south so would be a bit of a treck.
Old 19-Mar-2006, 12:14   #5
I know someone who uses a split link on his 350hp drag bike without any problems.
When you think about it there is no reason why it should be weaker than a riveted link, there are no sideways loads on the chain and the pins going through the links are the same material as the rest of the chain.
I guess bikes are manufactured with endless chains becasue its one less job for them to do on the production line.
Old 19-Mar-2006, 12:35   #6
I use C type links in work all the time , but i would not use em on my 998 , maybe thats just me
Each to their own i guess
Old 19-Mar-2006, 12:42   #7
yeti yeti is offline
yeti's Avatar
RH is right, there IS NO reason why these should be any weaker. That said, I'm not sure I would ever want to trust one because I have seen them fail in the past.
Old 19-Mar-2006, 14:21   #8
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
I have a pair of link tools here near Wimbourne. I'll give you a quick lesson if you drop around.
Rgds, Rob
Old 19-Mar-2006, 18:21   #9
Rgds, Rob
Thanks, I appreciate that. I will order the kit this week.
Does anyone know a good place for chains and sprockets ?
Old 19-Mar-2006, 19:36   #10
B&C Express.
www.bandcexpress.co.uk
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:01.
