Old 21-Mar-2006, 10:39   #1
TonyH TonyH is offline
TonyH's Avatar
Mood: Bits fitted service done, Nice
Is it possible (Speedometer question)
I have a 1995 750SS and the speedo indicator needle has faded over time, is it possible to change the needle.
I've only had the bike a couple of days so I thought I'd ask the question before I start pulling it to bits.
Old 21-Mar-2006, 11:31   #2
Hmmmm, I believe the unit is just a 'pod' that sits in the surround. Dunno about changing the needle - why not try to to remove the outer surround and the glass cover and simply repaint the needle with some Fluro / bright paint of some sort?
Speedo's come up pretty regular on FleaBay - but stripping two units down to swap needles over seems extreme to me.
Good luck ! Frank
Old 21-Mar-2006, 12:35   #3
TonyH's Avatar
I agree, I should have worded the question better, it should have read can I get to the needle rather than replacing it. Thanks Frank
Old 22-Mar-2006, 11:47   #4
There again......
http://cgi.ebay.co.uk/DUCATI-750SS-7...temZ8049248095
F
Old 27-Mar-2006, 03:45   #5
edwyun edwyun is offline
the gauges are sealed units and it's very difficult to remove the bevel without damaging the glass. if you send it to a professional, they could prolly open the gauge up and paint the needle carefully.
dunno about the UK, but many in the USA use these guys...
<www.paspeedo.com>
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:01.
