Old 25-Mar-2006, 20:15   #1
DUCATIBLUE DUCATIBLUE is offline
Mood: CALM
ST2 Running fault
Hi, I wondered if anyone can make an educated guess as to my ST2 problem. It's done 37k . problem started today. after an hour of motorway , whilst cruising at 90-100 if I reduce the throttle by only a little bit , instead of just slowing down the engine stops firing completely as if I had let go of the throttle . If I open it up a little bit it fires and runs as if nothing is wrong. It has made the throttle into an on /off switch ! I'm guessing the TPS has reached it's sell by date or maybe one of the other sensors? I tried it many times over the next 100 miles but the problem won't go away . Many thanks for any suggestions. Fraser
Old 25-Mar-2006, 20:26   #2
Yup sounds like a TPS problem to me
Old 29-Mar-2006, 11:22   #3
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
Yep, throttle sensor...not to expensive
Old 29-Mar-2006, 13:54   #4
About £125 plus fitting and set up. I call that expensive!
Old 29-Mar-2006, 19:20   #5
Mood: CALM
Many thanks for your suggestions, I think the TPS is the way forward. If it costs under £ 200 all in , I have no complaints after 37k trouble free miles . cheers Fraser
Old 29-Mar-2006, 19:22   #6
If you are lucky you can pick them up on ebay. I've got one from a two year old bike that was being broken which only cost me £5.00.
