Old 27-Mar-2006, 18:46   #1
900MAN 900MAN is offline
900MAN's Avatar
Mood: 900 went 999 gone, Multi came and went, 749 Nero now
Arrow Pipes on Ebay and ECU stuff again
YES
Just won a pair of Arrow carbon cans on ebay.
Wondered if you need to change the ECU on my 900ss?
Old 27-Mar-2006, 20:43   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
A Power Commander would be a good idea imo. I bought one and set it up at the weekend in conjunction with some high-level pipes and a modded aibox - I got an extra 5-6bhp right through the mid-range.
Well worth doing a job properly.
Old 27-Mar-2006, 22:38   #3
900MAN's Avatar
trouble is, a power commander is £270ish?
Old 28-Mar-2006, 20:46   #4
And how much is your motor if you run it too lean?
Old 28-Mar-2006, 21:05   #5
Felix Felix is offline
If your model is in the following list you can change the software via "flash load". I don't know what it costs anymore but used to be around £100. [list=1]UMF003 - 900ss 1998/9, Slip-on Mufflers
UMF005 - 900ss 1998/9, Slip-on Mufflers and Modified Cam Timing
UMF007 - 900ss 1998/9, 944cc kit, DP cams,valves, Slip-on Mufflers
UMF013 - 900ss 2000, Slip-on Mufflers
UMF015 - 900ss 2000, Slip-on Mufflers and Modified Cam Timing
UMF021 - 750ss 1998/0, Slip-on Mufflers
UMF031 - 750ss 2000, Slip-on Mufflers
UMF043 - Monster 900ie 2000, Slip-on Mufflers
UMF045 - Monster 900ie 2000, Slip-on Mufflers , Modified Cam Timing
UMF051 - 900ss 2001, Slip-on Mufflers
UMF055 - 900ss 2001, Slip-on Mufflers and Modified Cam Timing
UMF061 - 900ss 2002, Slip-on Mufflers
UMF065 - 900ss 2002, Slip-on Mufflers and Modified Cam Timing[/list=1]
Have a look here: http://www.fuelinmoto.com.au/fimnews.html#FLA
You may have to replace your ECU with a programmable one in which case the power commander is the less expensive option. I'd definitely get the mapping checked as these bikes tend to run lean to pass emissions. Speak to someone like Nelly (on this board) who know a lot more than me.
[Edited on 28-3-2006 by Felix]
Old 29-Mar-2006, 14:19   #6
900MAN's Avatar
Ok Got the cans just need to take her out to see how it runs.
Have a couple of options on the ecu now, the mega bucks one natty has up for grabs, or one from misterpink that seems to be the uprated item that comes with DP cans for the price of a bottle of wine.
Old 29-Mar-2006, 14:24   #7
900MAN's Avatar
Ps Cant beleive how much lighter the pipes were
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:07.
