Old 27-Feb-2014, 19:16
serious4play serious4play is offline
848 evo clutch help please
Hi guys, need help please I have a 2011 848 evo with 2500 miles on it and I wanted to put an aftermarket clutch slave cylinder on it and stumpy levers. I bought GNC levers and a factory racing clutch slave and put them on last night.
Problem is now when I select 1st gear and let clutch out the bike hardly moves it's like it's riding the clutch and the clutch isn't engaging totally, it was bled with and draper air compressor bleeder and I left it overnight with clutch cable tied in but it still isn't engaging!!!!!
Any thoughts or help please greatly appreciated thanks .
Old 27-Feb-2014, 21:13
Do you know what piston diameter the clutch slave is?
To get a lighter action the piston is bigger than the oem size BUT to push the same amount of fluid and move the clutch push rod the same distance will mean that you will have to pull the lever further. This is the trade off.
Have you tried setting the span adjuster so the lever is all the way out?
The other thing you could do is to wind out the barrel adjust slightly - the bit that pushes into the master cylinder - but be careful not to do it too much otherwise it will drag the clutch.
Old 27-Feb-2014, 22:50
Some of these aftermarket slaves have a spacer against the piston, if it is installed it may want removing. What you have at present is a pushrod that is too long. So check up the bore of the slave cylinder.
Old 28-Feb-2014, 08:42
Normally you'll get a locked clutch (as in, not able to pull the lever) if the adapter (10mm long) is installed on the later clutch.
The shorter pushrod that needs the adapter was on models up to ~2000 so a lot of companies don't bother with it any more!
Old 28-Feb-2014, 21:59
I would try refitting the original clutch lever and see what it is like then, if its still a problem then its something to do with the fitting of the Slave Cylinder.
I've been using a Factory Slave cylinder on mine for a few years now without any problems even with a short lever
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:00.
