Old 01-Apr-2006, 22:26   #1
duc daz duc daz is offline
duc daz's Avatar
condensation
while checking the bike over and giving it a clean the other day i noticed that there was condensation on the oil level window is this normal ??????????
Old 01-Apr-2006, 22:51   #2
desmobob desmobob is offline
desmobob's Avatar
Mood: Beige.....
Have you been running it up over the winter in between storage ?
I've been told that running a bike up without using it, (which is what I USED to do in the winter) - is the worst thing to do.
Parts heat up too quickly as the engine hasn't got any cooling air running at it.
Running it up without using it or running it to a temperature that won't dispel any condensation can cause such an issue.
Old 01-Apr-2006, 23:18   #3
duc daz's Avatar
ive used it through the winter and the bike has always got up to temperature
Old 01-Apr-2006, 23:25   #4
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Just because the temp' gauge shows normal it doesn't mean that the engine temperature is normal. The gauge is only showing water temperature - actual engine temperature can be somewhat lower in winter.
Old 02-Apr-2006, 00:32   #5
The Big Red One The Big Red One is offline
Mood: Sparks will fly. If it keeps on
Ducati said to me nothing to panic about i had the same. Some do a some don't
Old 02-Apr-2006, 00:41   #6
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Daz just allow the engine to run a while or go for a spin and all the vapour will disappear.
Old 03-Apr-2006, 16:22   #7
DSC Region Organiser TORTUGA TORTUGA is offline
TORTUGA's Avatar
Comes and goes on mine, Usually when it is cold weather. Such as the other week. I bet it will dissapear as it warms up.
Old 03-Apr-2006, 21:26   #8
duc daz's Avatar
cheers guys .it will put my mind at rest
Old 03-Apr-2006, 22:08   #9
HW HW is offline
seen that on 749 and ST2 from time to time ... nothing to worry about apparently.
Old 04-Apr-2006, 21:18   #10
Carbon749's Avatar
Mood: I own a flame thrower
A natural effect of running an engine and letting it cool in damp winter weather will form condesation on hot engine parts as they cool.
Engine oils have emulsion agents to help disperse this condensation in the engine oils. The first decent long run on a warm day will heat up the oil and engine parts to the right heat that will "flash off" the condensation.
Basically, nothing to worry about.
