Old 03-Apr-2006, 10:39   #1
Mood: wobbly !!!
Cylinder oil leak HELP please
After dropping out the engine and changing the O rings on the rear cylinder head its still leaking oil from that area.
Is there any other reason for the leak please ?
I know they all weep a bit but mine is chucking it out. I thought that the O rings would cure the problem.
Its a 91 900ss.
Help Kev !!!!
Old 03-Apr-2006, 11:16   #2
Is it deffo the head - or are you spotting the oil deposits on the crankcase top?
If thats the case it could be the oil breather instead.
Only other things I can think of from the top of my head (after a nightshift) - is valve cover / head torque not correct / oil feeds ???
Good luck - Frank
[Edited on 3-4-2006 by Iconic944ss]
Old 03-Apr-2006, 11:27   #3
Mood: wobbly !!!
Its the head, the top 6 cooling fins are dry as a bone.
The one on the joint is wet with oil.
Why should it still leak after changing the O rings ?
Operation went without a hitch. All changed over with no drama.
Is there another answer?
Oil breather was changed a month ago.
Help
Old 03-Apr-2006, 11:29   #4
Henners Henners is offline
Considered a nice VFR ??
Old 03-Apr-2006, 12:01   #5
Henners...dont be naughty and go directly to the H*nda forum !!!
Kev, I didnt realise the head is only sealed using the 'O' rings - I honestly thought there was a gasket of some sort on top of the barrel.
Looking at the parts pdf it shows TWO DIFFERENT part numbers for the O rings used - could you have used wrong ones or got them mixed.
Otherwise - I'm stumped and can only think of awful things like distorted head or barrel OR perhaps your oil pressure is running too high for some reason...
CALL FOR SUPER-NELLY !!!!!!!!!!!!!
Sorry - Frank
Old 03-Apr-2006, 13:49   #6
Mood: wobbly !!!
There are two different size O rings. One small one and two large.
Or did you mean two different types ?
Old 03-Apr-2006, 14:33   #7
UKRR UKRR is offline
Mood: Got the S - waiting for the Termi's
My SS had an oil leak when the cylinder stud snapped - a common faul with early SS engines.
Strengthened studs are available
Old 03-Apr-2006, 15:30   #8
Mood: wobbly !!!
No problems in that department all studs are at the correct torque. Thats what I cant understand, everything is as it should be !
Old 03-Apr-2006, 15:33   #9
Dibble
so all your studs are up to the job ??? Mrs Leader will be happy .... shame about the messy leakage though ..... :P
cheers for the cuppa yesterday .....
Old 03-Apr-2006, 16:12   #10
Sounds like something's warped Kev ...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:38.
