Old 03-Apr-2006, 20:20   #1
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Clutch (Again). Bit of Advice Please
well i got all the plates out and managed to clean them up without any major mishaps and it seems to have made quite a bit of difference. it's still slipping a little bit when i test it by doing a high gear "roll-on", but in the lower gears it seems reasonably ok.
however, when i had the plates out, it was clear that the friction plates are not much longer for this world - they're all very low and one was almost down to the metal.
is replacing the plates something i can do myself - ie: is it just a case of opening the packet and slotting the plates in in the correct order, or is there more to it than that? is there any set-up required due to the change in thickness of the new plates compared to the old ones?
if it's something i can do myself, i will do.... where is the best place to buy plates and are there any upgrades (i've read that aluminium "steels" were a good upgrade)?
thanks as always
Old 03-Apr-2006, 20:49   #2
Dibble
yes, its as easy as you just said, call Nelly, he will advise the best clutch plates, apparently there is a sensible cost upgrade, just can't remember the correct plate set ..... if you get them from Nelly he'll send them out in the correct order of plain / friction plates so you can just slot the pack straight in ....
www.cornerspeed.co.uk
Old 03-Apr-2006, 21:17   #3
raykay748R raykay748R is offline
Bikes: 748R, ZXR 400
raykay748R's Avatar
Mood: Glad to be back down south.
Where abouts in the country are you mate? You never know, some kind soul may come round and lend an expert hand if you're in their area, all for the price of a cuppa or two. Me in wilts/hants border.
Old 03-Apr-2006, 21:51   #4
You want a set of ST4S alloy friction plates.
Be aware though that even when they are new they don't have as much material on them as you might expect! I got quite a supprise when i opened up my first set!
Its worth going over the steel plates with fine glass paper if you didn't already do that.
Old 03-Apr-2006, 22:01   #5
zhed44's Avatar
Mood: YELLOW!!!
i'm in "that lundun" worst luck. what a place to own a ducati - no wonder my clutch is on it's way out!
Old 03-Apr-2006, 22:05   #6
Dibble
where in London Zhed ??? i'm in SE .. there are a fair few of us about ...
Old 03-Apr-2006, 22:06   #7
zhed44's Avatar
Mood: YELLOW!!!
are the st4 plates better (grippier) or just lighter? do you get alloy "steels" as well, or have i read the interweb wrong (i think i saw that last bit on sigma's website)
i gave the steels a bit of a rub with 120(i think) paper, but that looked a bit extreme so i just went at them with a scotchbrite pad and some elbow grease. i also cleaned up the friction plates with brake cleaner and a cloth. it seems to have done the trick .................for now
thanks
[Edited on 3-4-2006 by zhed44]
Old 03-Apr-2006, 22:09   #8
zhed44's Avatar
Mood: YELLOW!!!
way, way north - just south of friern barnet/arnos grove area.
it's lovely of you to offer, but if it's as simple as everyone is saying, then given that i managed to get the olds plates out and in again not only without breaking or losing anything, but also with a marked improvement, then even i should be able to manage on my todd!
Old 03-Apr-2006, 22:16   #9
The alloy plates are a lot quieter and they don't bash the basket as much as steel ones. I haven't found any downsides apart from them costing a couple of quid more that steel ones. There probably is some power advantage becasue they are lighter but i doubt you'd notice.
I think my last set came with all the steel driven plates as well.
Old 03-Apr-2006, 22:19   #10
zhed44's Avatar
Mood: YELLOW!!!
one other thing i'd like to pick your brains on please - what's the easiest way to fish the last few plates out? i had a "one screwdriver in each hand, tongue poking out of the corner of my mouth" thing going on, but it was pretty damn fiddly.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:06.
