Old 08-Apr-2006, 10:25   #1
yorkie yorkie is offline
Bikes: 900 Monster, 750 SS Cafe Racer
yorkie's Avatar
Another snapped chain!!
Yet again just as everything was going fine this happens:
Firstly the seat release cable snapped underneath the seat, so i have to strip the underside down, bugger!
I decide not to let it bother me and ill go out for a blast, to cheer myself up!
I get to about 80, after slowing down, just about to get to the roundabout, and i loose all power and hear a grinding noise!
On looking down, the chain is rubbing my swingarm up!! Double Bugger! (This is the third one) On a 600 Monster??
On closer inspection the chain link had snapped on one side, throwing it off the sprocket (Taking a couple of teeth with it).
The damage 2 knackered and one powdercoated swingarm complete with scratches and grooves!!
I have 2 spare swingarms but i a looking for a 900 alloy jobbie if anyone has one!
Yorkie
Not too P***ed off!! All my chains are well lubed and adjusted well??
[Edited on 8-4-2006 by yorkie]
Old 08-Apr-2006, 10:42   #2
FiscusFish's Avatar
Make?
Old 08-Apr-2006, 10:55   #3
yorkie's Avatar
Little monster!!
Yorkie.
Old 08-Apr-2006, 11:08   #4
Founder Member
Paul James's Avatar
Originally posted by yorkie
Little monster!!
Yorkie.
Little monster always were a crap chain manufacturer :P:P
Is there an alignment problem or are you (maybe) running it a bit on the tight side ?
The ST's need a bit of extra chain slack if you are a heftyish sort of rider, the 2 and 3 if adjusted to spec are very tight two up with luggage.
Old 08-Apr-2006, 11:16   #5
yorkie's Avatar
Chain was DID with renthal alloy sprockets, adjusted to spec and checked (Alignment) on the last MOT, last week!!
All was fine till i rolled it out of the garage, im thinking shaft driven for a change!!
(NOT)
Yorkie.
Old 08-Apr-2006, 11:44   #6
Get Tsubaki drive
Old 08-Apr-2006, 11:46   #7
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
With all due respect, Yorkie you must be doing something wrong to be suffering this problem so often - it's too much of a coincidence - or you have a mechanical problem somewhere that is killing the chains.
Whereabouts in North Yorks are you?
Old 08-Apr-2006, 11:51   #8
yorkie's Avatar
Well its not too much power!!
Near Ripon!
Yorkie.
Old 08-Apr-2006, 11:54   #9
Ah righto. Would you like a 2nd pair of eyes to help you? I'm in Darlington.
Old 08-Apr-2006, 11:56   #10
yorkie's Avatar
Ill drop you a PM, hopefully i will have the set by Tuesday!!
Yorkie.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:35.
