Old 08-Apr-2006, 18:43   #1
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Calling Right Said Fred
Did those carbon tank shields fit the 888 tank Lynds?
Rgds, Rob
[Edited on 8-4-2006 by Rob B]
Old 08-Apr-2006, 22:05   #2
RightSaidFred's Avatar
Rob
Yes and no. Yes they will fit a perfect tank, sadly mine's not...
As you know the tank's your old one. I originally had a carbon protector on my red tank. I took it off and tried to fit it to yours and it wouldn't go. I tried heating it and buggered it up. So I thought maybe it was the protector, so I bought 2 of these new ones. They're the same. Fit the red tank fine but not the black one.
Basically it looks like matey has repaired it slightly on the ****. It's weird cos it looks perfect, but it's obviously not.
Oh well. I might try to heat one a different way this time, but i'm not sure how to work carbon and resin without it going kinda cloudy.
Old 11-Apr-2006, 12:29   #3
Rob B's Avatar
Once the epoxy/carbon has reacted (gone off) you can't soften it with heat. All you do is burn the epoxy and char the carbon. That assumes it's good stuff.
If you have a spare, you could send it down, I'll buy it if it fits the carbon tank.
Rgds, Rob
[Edited on 11-4-2006 by Rob B]
Old 16-Apr-2006, 03:05   #4
Rob
You're welcome to try the spare, only thing you may not want is that it has '851' sort of moulded into the epoxy. I didn't mind but you might. If you want it, it cost me 18 bucks plus a couple of quid post. U2U your address if you want a look at one and i'll fire it down.
Old 17-Apr-2006, 12:34   #5
Rob B's Avatar
Ah, that throws a spanner in it then...
Old 18-Apr-2006, 02:04   #6
My 888 is such a rattly old tool it sounds like I already have thrown a spanner in it!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:23.
