Old 09-Apr-2006, 11:32   #1
posiden posiden is offline
EOBD light wont go out
AAAARRRRGGGG went to go for a run this morning and my 749 wont start. the eobd light wont go out - engine is turning over and the dash is clear of any other warning lights. checked all the fuses and thier OK.
can anyone help ?
[Edited on 9-4-2006 by posiden]
Old 09-Apr-2006, 11:44   #2
With the ignition off, hold down the left button on the dash whilst turning the ignition on. Keep a hold of the button for a few seconds then realease.
The error code screen should appear with a code displayed as to why the EOBD light is lit.
There's a list of the error codes somewhere on the board to check against.
Old 09-Apr-2006, 12:34   #3
cheers nelly, im getting codes 10.2 horizontal coil short to eath,12.2 injector 1 short to eath and 13.2 injector 2 short to earth.
going to have a look now with a 7 lb hammer.
Old 09-Apr-2006, 15:42   #4
galaxy galaxy is offline
Anyone got a link or that list of codes??
Old 09-Apr-2006, 16:17   #5
749 / 999 Error Codes ?
Ive copied these from this site searching for "error codes"
To get the codes up you need to pres the left hand button on the clock assembly and keep it pressed when you turn the ignition on - the codes then are displayed.
1.1 TPS Disconnected
1.2 TPS short circuit to earth
2.1 Pressure Sensor short circuit to power supply
2.2 Pressure Sensor shorted to earth
3.1 Water Temp Sensor shorted to power supply
3.2 Water Temp Sensor shorted to earth
4.1 Air Temp Sensor shorted to power supply
4.2 Air Temp Sensor Shorted to earth
5.1 Battery Hi
5.2 Battery Lo
10.1 Hor. Coil shorted to power supply
10.2 Hor. Coil shorted to earth
11.1 Ver. Coil shorted to power supply
11.2 Ver. Coil shorted to earth
12.1 Inj1 shorted to power supply
12.2 Inj1 shorted to earth
13.1 Inj2 shorted to power supply
13.2 Inj2 shorted to earth
14.1 Inj3 shorted to to power supply
14.2 Inj3 shorted to earth
15.1 Inj4 shorted to powersupply
15.2 Inj4 shorted to earth
16.0 Pump Relay
17.1 LH Fan shorted to poer supply
17.2 LH Fan shorted to earth
18.1 RH Fan shorted to power supply
18.2 RH Fan shorted to earth
19.1 Starter Solenoid shorted to power supply
19.2 Starter Solenoid shorted to earth
30.0 ROM/Eprom error
34.0 Signal Panel Sensor
36.0 Speed sensor
37.0 Immobiliser (transponder)
37.1 Immobiliser (antenna)
37.2 Immoiliser (instrument panel serial driver)
37.3 Immobiliser (serial cable disconnected)
37.4 Immobiliser (ccm serial drive)
37.5 Immobiliser (key not recognised)
37.6 Can Line error
Old 09-Apr-2006, 18:26   #6
Loz Loz is offline
Loz's Avatar
This thread is now bookmarked!
Thanks, fellas and hope you get your 749 sorted!
Old 09-Apr-2006, 19:10   #7
sorry Loz, thats an eror code tw8t:1! it means youve dropped the bike again!
Old 09-Apr-2006, 20:04   #8
audicdl audicdl is offline
Mood: Optimistic
You haven't washed it recently have you? Mine gave the same symptoms recently and gave at least one of those fault codes. I had to have it recovered to the dealers. It turned out to be the fuel pump relay which is situated behind the battery, right where the front wheel can chuck up water etc. at it.
Old 09-Apr-2006, 20:32   #9
bolds bolds is offline
Yeh from those error codes it looks like pump relay
Old 09-Apr-2006, 20:38   #10
tricky tricky is offline
Mood: Need spares
I've had that go on me, apparently the connections on the relay were corroded.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:10.
