Old 09-Apr-2006, 18:25   #1
Mood: childish
voltage leak (on car) can you help?
i got fed up with jumpstarting my car every 2 days so i got the multimeter out today. set it to amps, removed the -ve terminal and connected it in line.
ive read that a drain of 0.075A is enough to drain a car battery overnight & i saw a reading of 0.22A with ign off & interior lights etc off.
i then removed & fuses & found the current dropped to 0.02A when the central locking fuse was removed.
what can be causing this voltage leak? i dissconected the 2 central locking motors in the doors ( i was about to dissconect the boot & fuel cap motor/solenoid but it started raining!)
any ideas would be appreciated
rus
Old 09-Apr-2006, 19:12   #2
Sounds like one of the motors is screwed. Be a good idea to disconnect them one at a time to isolate it, then replace it.
Old 09-Apr-2006, 19:20   #3
AL900SL AL900SL is offline
AL900SL's Avatar
Mood: Poor Grammer
What car is it Rus and does it have an OE or after market alarm. Does the alarm plip activate the locking, as it could be a drain throught this.
Old 09-Apr-2006, 20:58   #4
Mood: childish
will be checking the other C.L. motors ant.
AL, its a bmw 320 with an o.e. alarm, but it does seem to appear to be coming from the C.L. circuit, i just thought the doors would be locking 7 unlocking to have to be using current??
cheers though
Old 10-Apr-2006, 00:16   #5
Loz Loz is offline
Loz's Avatar
BMW, eh? Probably the electronic management system working out Pi to 150,000 decimal places.
<runs away>
Old 10-Apr-2006, 00:56   #6
final_edition's Avatar
Also check the CL switches for continuity.
Old 10-Apr-2006, 11:48   #7
uncle porry uncle porry is offline
uncle porry's Avatar
could be a relay stuck on & drawing power constantly...might be worth checking the c/l locking relay...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:38.
