Old 10-Apr-2006, 23:10   #1
flanagaj flanagaj is offline
low revs chatter
If I pull away in 1st using low revs and no clutch my 748 chatters along. If this usual ?
Old 10-Apr-2006, 23:19   #2
Dibble
no clutch ??
if you mean it kind of hunts in the rev range and lurches a little thats just the engine being lumpy at low revs, might also be worth checking the state of your chain tension and sporocket condition .....
Old 11-Apr-2006, 08:44   #3
No Duke that I've ever ridden has felt happy without the engine doing at least 2.5K revs - preferably over 3K revs.
Try and chug along at lower revs than that and the engine will be very lumpy. Even in low gears you often need to feather the clutch a little in traffic and around tight roundabouts
Old 11-Apr-2006, 18:54   #4
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
"they all do that sir"
low revs without clutch slip = "dumdumdumdumdum"
[Edited on 11-4-2006 by zhed44]
Old 11-Apr-2006, 19:03   #5
moto748 moto748 is offline
Yes, they all do do that, to an extent, but as Dibble says, it's worth checking chgain tension (not too tight!) and chain and sprocket condition. Can you lift the chain away from the rear sprocket at 9 o'clock?
Might be worth checking the condition of your clutch basket too.
Old 11-Apr-2006, 20:11   #6
I am changing the chain and sprockets this weekend. The clutch basket does have a few notches in it. How can you tell if it needs replacing ?
Old 12-Apr-2006, 13:36   #7
raykay748R raykay748R is offline
Bikes: 748R, ZXR 400
raykay748R's Avatar
Mood: Glad to be back down south.
And at any other time of the day too!!!!
Old 12-Apr-2006, 14:28   #8
Ouch, my sides!
Old 12-Apr-2006, 15:08   #9
Do you really mean chatter.....isnt that a technical term reserved for suspension/tyres?
Even the 748 has a pair of big pistons compared to a ujm. they need revs............
Old 12-Apr-2006, 15:17   #10
I've spotted the problem - you've got a Goldwing, not a Ducati
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:07.
