Old 13-Apr-2006, 16:58   #1
Wylie1 Wylie1 is offline
Wylie1's Avatar
Front wheel spindle very tight?
Whilst I was removing my wheels to get tyres changed, I noticed the front wheel spindle was quite hard to remove & replace.
Anybody else come across that?
Old 13-Apr-2006, 17:07   #2
Ducati Dealer
wilf's Avatar
all the time, they go out of shape very easily and the holes that the screwdriver goes through to adjust the compression get elongated. You sometimes have to tap them out, pretty hard.
Old 13-Apr-2006, 18:16   #3
khushy khushy is offline
khushy's Avatar
I have an almost new one for sale!
£30 incl p&p
Khushy
Old 14-Apr-2006, 11:17   #4
Don't overtighten the fork pinch bolts. They are only 19Nm, i've needed the 1/2" wrench on some of them followed by a big drift and hammer.
Old 18-Apr-2006, 17:27   #5
Wylie1's Avatar
£30 incl p&p
Khushy
Thanks khushy, but the spindle isn't as tight as I am!
It wasn't too hard to get out....just harder than I thought it should be.
Old 18-Apr-2006, 17:29   #6
Wylie1's Avatar
I've always tightened the pinch bolts using a good quality torque wrench, but it has had a tyre change that I didn't take the wheels off myself
Old 18-Apr-2006, 17:39   #7
khushy's Avatar
use loads of grease - you will be surprised at the difference it makes!
Khushy
Old 18-Apr-2006, 19:04   #8
Also found the inside of the spindle hole on the left leg roughed up before, where someone has tried to tap the spindle through without aligning the fork leg properly, ever since i have had a Ducati I have been using an alignment tool that I had noticed club racers using when I was at meetings prior to me owning a Ducati
Old 21-Apr-2006, 17:28   #9
748rosso 748rosso is offline
Mood: C'MON YOU IRONS !
Skidlids,where did you get the alignment tool from ?
Ducati part 8000.70139 according to my manual for the 749s.
cheers
paul
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:52.
