916 stuck in first gear my pals 916 trackbike is stuck in first gear, basically started it up selacted first gear and now it wont change gear or re-select nuteral. seems like the gear selector mat be stuck as the gear lever is fairly solid, so whats the likely cause, and how to put it right? seems like the engine side case needs to come of what if any special tools are needed , seals or gaskets are required to put it back together, should i need to take a look at the selector mechanisum? any advice please !!! |
