Old 24-Mar-2014, 19:11   #1
r15suk r15suk is offline
r15suk's Avatar
Worn Clutch Basket - Help Required
Hi,
Attached are a couple of pics of my clutch basket. Can anyone tell me if they feel that the clutch basket is excessively worn is is it normal?
Simon
Old 24-Mar-2014, 19:44   #2
dunlop0_1's Avatar
Simon.
It's worn but IMO not excessively. Like it is the only side effect would be the clutch noise will be a tad louder, more so if you run steel friction plates.
Steel baskets are usually cheap on fleabay.
These aluminium ones are good value considering a UK seller is trying to flog a used one at the same price..
http://www.ebay.co.uk/itm/Ducati-Alu...item20e18b3b5f
Neil
Old 24-Mar-2014, 19:52   #3
r15suk's Avatar
Originally Posted by dunlop0_1
Simon.
Neil
Thanks for the prompt response :-) I guessed that it might be ok but wanted to make sure. My VFR has similar wear and thats ok, but the Ducati being a dry clutch i wanted to make sue. I don't mind a bit of noise
I'll take a look at the eBay link.
Simon
Old 24-Mar-2014, 21:23   #4
Looks no worse than the one on my Hypermotard at the moment!
It might screech a bit more when pulling away due to the plates not freely moving in the basket, but they certainly won't get stuck with yours.
When they get really notched/ridged you can always dress them lightly with a file or sandpaper to take the roughness off and allow them to slide again.
Old 24-Mar-2014, 22:14   #5
r15suk's Avatar
Nice one, ta.
simon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:25.
