Old 15-Apr-2006, 18:23   #1
Henners Henners is offline
Help: bleeding rear brake line
You'd think I'd have this sussed by now but having fiited new brake lines to the 996 I can't get the rear line bled Tried everything and in the end gave up. Is there a kit that will draw the brake fluid through a new line or some other solution? Cheers H.
Old 15-Apr-2006, 19:49   #2
Take the rear wheel off. Remove the rear caliper and sit it on the top of the disc. This will put the bleed nipple at the top of the system.
The bleed as normal. It'll take some pumping at first, but once the fluid starts to flow, it'll come good...............
Old 15-Apr-2006, 20:22   #3
GsxrAge GsxrAge is offline
GsxrAge's Avatar
As Nelly says
works everytime
Old 15-Apr-2006, 21:03   #4
Thanks guys - tried that, didn't work today although it has in the past.
The gifted Mr Alan Knight has been in touch with offers of assistance so the jobs a good 'un
Old 15-Apr-2006, 21:09   #5
GsxrAge's Avatar
Ya can't be twisting your nipples right
Old 15-Apr-2006, 21:15   #6
Jasper Jasper is offline
Jasper's Avatar
Did mine the other day!!4 hours to finally get it done!!
Old 15-Apr-2006, 21:43   #7
Gizmo Gizmo is offline
Mood: is it the weekend yet??
on mountain bikes we usually bleed backwards, attach a syringe filled with fluid via a plastic pipe to bleed nipple, open it and push fluid back to master cylinder. close just before you stop pushing syringe. on an mtb system its real small volume so even a small air bubble is noticed so pushing from low point of calliper lets air travel upwards . you'll need to make something to catch fluid as it exits at the resevoir, we had custom cap covers done with a hole and pipe attached to drain to a bottle.
Old 15-Apr-2006, 22:37   #8
No HR answer to this one then?
Old 15-Apr-2006, 23:26   #9
Thanks Michael - that'll be the way to go if Jasper and I are anything to go by.
Andy - we've had a focus group, consulted the key stakeholders, done a SWAT analysis and still no performance improvement. I've even threathened the offending caliper with a Haynes manual and still no joy. Looks like a strong talking to by a upstanding officer of the law is required. Any idea where I'd find one of those
Old 16-Apr-2006, 08:58   #10
Stu748R Stu748R is offline
Mood: I've just ordered a new bike and its a ..
Yea,Box hill today.....................
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:58.
