Old 15-Apr-2006, 19:35   #1
clarkmeister clarkmeister is offline
Aftermarket shock for 748 - any advice?
Hi peeps...
Have got no damping in rear shock on my Y2000 748E (due to leak). Does anyone have a new or serviceable unit that I could buy? Failing that, any info/experience on replacements (eg Hagon) gratefully received. Thanks in anticipation, Ian.
Old 15-Apr-2006, 19:37   #2
Dibble
Ohlins is the most common upgrade.
Old 15-Apr-2006, 20:12   #3
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello clarkmeister
you can get it serviced, but as said Ohlins is the upgrade.
regards
TopiToo
Old 15-Apr-2006, 22:48   #4
Thanks for the advice guys but have now got a replacement lined up, thanks to chris.p
Old 21-Apr-2006, 01:57   #5
CipiVTS CipiVTS is offline
CipiVTS's Avatar
Hi,
i also have a 748E 2000 frame, but i really cannot tell what shock do i have at the back. ( i think it's not SHOWA)
What's the standard fitment?
Regards
Old 21-Apr-2006, 02:40   #6
I think the 748E may run a sachs shock.
Has anybody tried a 749 or 999 shock on the earlier models as these would only be a few years old at most and generally be in better condition than a used 748/916 shock
Old 21-Apr-2006, 09:48   #7
frazelli frazelli is offline
Mood: whatever!
I asked at my local dealer about a 749/99 shock for my 748 and was told they are different and do not fit, so ended up going with an Ohlins instead!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:17.
