Old 15-Apr-2006, 21:28   #1
flanagaj flanagaj is offline
Can\'t remove oil filter :-(
I stupidly thought that to save a few pounds and to learn a bit about servicing that performing an oil change myself was the way to go.
I tried to remove the filter using a removal strap that a friend lent me. Would not budge. SO I then stupidly banged a screw driver through it and that has just torn the filter.
Any ideas. Looks like I may well be going to Mondays BSB in the car.
Old 15-Apr-2006, 21:33   #2
GsxrAge GsxrAge is offline
GsxrAge's Avatar
hmmm you just have to struggle now
Old 15-Apr-2006, 22:04   #3
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello flanagaj
Halfords do a oil fitler nylon strap with a socket head,
good for getting leaverage.
I think they also do a chain version, but this is a pig to get
round the filter.
and use a this to tighten the filter up, a touch after hand tight.
good luck
Dont forget that oil catcher
regards
TopiToo
Old 15-Apr-2006, 23:03   #4
aka.eric aka.eric is offline
Tighten a jubilee clip aroud the filter and undo with a C spanner.
Old 15-Apr-2006, 23:04   #5
Easy to try and unscrew the filter the wrong way when your lying on your back and the filter is upside down!
Old 15-Apr-2006, 23:13   #6
Just whack a long screwdriver through it a turn it out like everyone else does
Old 16-Apr-2006, 00:56   #7
Mr_S Mr_S is offline
Since you've already tried the screwdriver method, and probably don't have enough filter left after tearing it for a strap wrench, you'll have to try drifting it out very gently.
There is a specialist tool available for extracting torn / damaged oil filters, but I can't remember the name.
Old 16-Apr-2006, 01:50   #8
keefer keefer is offline
keefer's Avatar
stab it
Old 16-Apr-2006, 04:00   #9
sbwells sbwells is offline
sbwells's Avatar
Mood: Bring the noise!
That's the way mate. When in doubt get medieva on its ass
Old 16-Apr-2006, 11:02   #10
Totto Totto is offline
If some one has a broken oil filter ,could they send it to me and i will try and make something up to remove it while its on the bike , ,once i get back to work that is
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:44.
