Old 17-Apr-2006, 07:54   #1
Paul D Paul D is offline
Paul D's Avatar
Mood: Ground,sky,ground,sky,ground....
996 SPS Track Bike
I have found a 996SPS track bike (Year 2000, but I assume early as it has Showa forks) , 5000 miles, says well maintained, any ideas what to look for to confirm how well its been looked after if the paper history is not complete?
Also what is best to look for to confirm its a true SPS, not just sporting a swapped top yolk!?
Old 17-Apr-2006, 19:01   #2
you can check the frame number with Ducati UK - as for the maintenance - check service history with the dealers who stamped the book.
Tim
Old 17-Apr-2006, 21:28   #3
ducv2 ducv2 is offline
Think the front head casting shouldnt have 4vDOHC cast into it if its a genuine SPS
Old 18-Apr-2006, 12:25   #4
RickyX RickyX is offline
RickyX's Avatar
I believe that rule only applies to 748SP's. 916SPS has "4VDOHC" cast on it.
Look for:
P8 computer
Dual pickups on LHS engine case
Ohlins rear
But mainly check the engine number with DUK.
RX
Old 18-Apr-2006, 21:02   #5
Look for:
P8 computer
Ohlins rear
RX
My 996 SPS has a blank head casting
Old 18-Apr-2006, 21:47   #6
If its an SPS - it'll have a large computer (P8) under the seat unit.
I don't think these were fitted to any other bikes.
Tim
Old 18-Apr-2006, 22:01   #7
Paul D's Avatar
Excellent, thanks for your help guys. I am going to look at the bike in the next few days so I will let you know how it goes.
If it is a good one you will see another 200 posts on the message board about setting a 996SPS up for the track!
Old 19-Apr-2006, 12:48   #8
RickyX's Avatar
Ooooh...I will check mine later tonight!
P8 computer also fitted to original 1994 916 Strada. Strada does not have dual injector bodies though (check by looking to see dual feed to injectors).
RX
Old 19-Apr-2006, 17:49   #9
cast casings too...whatever they are
Old 20-Apr-2006, 12:28   #10
RickyX's Avatar
RX
You are completely correct ducv2 and I was (unusually ) wrong...916SPS has no writing cast onto the cylinder heads.
Bradders: I've never worked out how to spot the "sand cast casings" either!
RX
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:24.
