Old 17-Apr-2006, 14:00   #1
i porter i porter is offline
pro,s cons 50mm or 54mm
Hi all. got 50mm termis fitted. On the odd occasion Ive seen 54mm Termis on Ebay.
Any gains to be had by fitting them, or would you guys leave, as is. Thanks again. Ian.
Old 17-Apr-2006, 14:08   #2
yeti yeti is offline
yeti's Avatar
Almost any engine will gain power by allowing it to breath more easily, however there comes a point where it's too much.
I would say that simply fitting a bigger exhaust will increase your power a little, but to see real differences, you need to give the engine some work, not least porting the heads.
Old 17-Apr-2006, 14:31   #3
Thanks yetti. Ive had all the gasflow engine work done. Would I see a difference with 54mm Termis.
Old 17-Apr-2006, 14:33   #4
yeti's Avatar
More or less definately, but ask someone who knows what they are talking about first! I'm no expert.
Old 17-Apr-2006, 18:59   #5
I think that you will gain more froma 54mm system because of your engine mods, I'd check with JHP - that's where you had the mods right?
Also, you might run into clearance issues (swingarm) with a 54mm system (mag swingarm!!!! required). You will also need different fueling etc, remapped PC or new chip?
Check with Mr Hackett I reckon.
Tim
