Old 17-Apr-2006, 17:06   #1
Martinp Martinp is offline
Martinp's Avatar
Mood: 748ish
748 749 engine swap?
I know that with enough money and time you could fit and thing into any chassis, never heard it been done just wondering if anyone else had? Does the engine bolt in or does it require frame mods? and what about electronics and fueling?
Old 17-Apr-2006, 17:06   #2
Dibble
why ?? just curious ???
Old 17-Apr-2006, 17:37   #3
Ducati Dealer
wilf's Avatar
way too much trouble for what you'll gain. if you're going to do it use a 998/999 motor but you'll have to do a TON of mod, including a frame mod.
I'm always up for a project but in this case the best advise has to be sell the 748 and buy a 998 imo.
Old 17-Apr-2006, 21:15   #4
raykay748R raykay748R is offline
Bikes: 748R, ZXR 400
raykay748R's Avatar
Mood: Glad to be back down south.
Better still buy a 749, junk the bodywork, swing arm etc etc and fit the parts from a 748!!! Whaddya reckon???
Old 17-Apr-2006, 21:23   #5
bolds bolds is offline
Yeh could do that and enter vintage runs then
Old 21-Apr-2006, 02:10   #6
Martinp's Avatar
Mood: 748ish
Rockers!!!
Old 21-Apr-2006, 02:43   #7
May be worth giving a go if it was a 748R that you had with the larger engine mounts and the shower injection, otherwise as Wilf says there could be a huge amount of work and agro involved
Old 22-Apr-2006, 01:57   #8
cjsperf cjsperf is offline
its a piece of cake...
engine
exausts
throttle bodies
then use the original 16m computer and loom to run it...
i have a stroked 1100cc stretta running on 748 management...
Old 22-Apr-2006, 09:52   #9
raykay748R's Avatar
engine
exausts
throttle bodies
We need piccies, more details etc-----Please!!!
Old 23-Apr-2006, 13:42   #10
i built the motor with a 2 phase 900ss lightened and balanced crank into a 998 deep sump cases.
stock pistons were milled to get the deck height correct leaving the center raised to gain more compression.
a combination of the piston modifications skimmimg the heads and the extra stroke gives a measured compression of 14.1
own port work on heads and r cams so 150 or more hp is in reach...
just a normal modified 748 ecu and loom running the 999 throttle bodies..
if you want pics pm me your e mail..
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:34.
