Old 29-Mar-2014, 16:18   #1
whorlicks whorlicks is offline
checking regulator
hi, can someone point me in the right direction .
750ss 96
think its a 2 phase regulator with 2 yellow/ 2 red / and 1 white 1 black.
how do i check it ?
checked wiring for joints all tight.
bike starts fine if charged but after about 30 mins lights go dim and bike wants to die.
guessing regulator but unsure how to check it thanks in advance.
had a look on youtube but they dont show mine.
cheers all.
Old 29-Mar-2014, 18:43   #2
With the engine running and the charging system working correctly you should get a voltage reading across the battery of around 14.4 volts
There is a charging fuse on the right hand side of the airbox, if this blows or has a corroded connection it can stop the battery charging.
Also check the regulator has a good earth connection
Old 29-Mar-2014, 21:02   #3
Generic fault finding chart:
https://dl.dropbox.com/u/26653469/90...ng-diagram.pdf
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:23.
