Old 17-Apr-2006, 21:57   #1
remfanuk remfanuk is offline
oil light
oil warning light comes on after a few miles of riding, typically under 10. have just done a full oil change, inc filter, so i know there is plenty of oil in it. been told its oil pressure switch faulty...apparently quite common....anyone experience of this problem please?
Old 17-Apr-2006, 21:59   #2
Dibble
yep, very common, about £18 I think ......
Old 17-Apr-2006, 22:08   #3
ducv2 ducv2 is offline
If there is any oil weeping from it, its on its way out, 5 minute job to change
Old 17-Apr-2006, 22:36   #4
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
did mine on the st with a few miner probs
http://www.ducatisportingclub.com/xm...2317#pid212248
Old 18-Apr-2006, 07:27   #5
thanks! there has been a little weepage (?) from around the top of the switch. presume it does actually let the oil drop low if it leaks then? thought it might be electrical as opposed to a seal gone that shows a drop in pressure. its on order so should be here soon!!
Old 18-Apr-2006, 09:03   #6
Think that the weepage is a sign of the switch starting to fail, but as oil is'nt a good conductor of electricity maybe it affects the contacts?? Scared the living daylights out of me when mine failed
Old 22-Apr-2006, 19:49   #7
changed it today...and after a 20 mile non spirited run, no oil light coming on! hurrah! thanks folks.
Old 22-Apr-2006, 20:29   #8
Glyn's Avatar
the best way to blow them there oil switches is to slightly over fill your oil
if that is why it went the first time and you change the switch without taking out a bit of oil you'll soon bugger up the new one an all
cause thats what i did
Old 23-Apr-2006, 10:25   #9
will bear that in mind Glyn! my oil is on maximum after a full change, yet it didnt take the whole recommended amount, so hope it will be okay.
