Old 17-Apr-2006, 23:11   #1
Rev counter cable
After this weeks rideout the replacements I need include whatever it needs to get my rev counter working again.
I haven't had time to take a look at it yet, but with the symptoms being that one moment the rev counter was at 9K and the next it was on 0 - without me shutting off the throttle - I'd reckon the cable has bust.
Anybody got one?
At this rate my 888 is going to be like Triggers broom
Old 17-Apr-2006, 23:38   #2
monstermob 998's Avatar
i had this sevaral times on my 600ss --when i took the cable off it wasnt broken--each time i refitted the cable the tacho would work again-- then i realised that the little brass nut that is on the internal drive cable was in the wrong end-- it belongs at the bottom not the top end-- the purpose of the brass nut is that it holds the drive cable up into the clocks end not down into the drive end!!! ---- dont know if 888/851 is the same but might be worth a look before you buy a replacement
Old 18-Apr-2006, 07:24   #3
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Jools,
Might do. Check if yours is actually broken.
Rgds, Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:06.
