Old 01-Apr-2014, 21:38   #1
IpswichTony74 IpswichTony74 is offline
1989 900 Supersport running on one cylinder
Hi guys. So, I got the bike out of hibernation today and all was going well. Started gine snd ran fine for the two miles to the petrol station. When I restarted the bike it ran on one cylinder and did so on the ride home. I took out both plugs, cleaned them up and put them back in to no avail. I swapped the plugs over and it still ran on one, so I popped one ht lead off, then the other and found that the front, or horizontal, cylinder is the one not running. Thats where my ability ran out. I did take the tank off because I could smell petrol and founf the Y joint completely split and I fid notice a blue wire from the back of the rectifier was not tight and wasnt making contact on anything other than hanging on the bolt (the wire runs to the negative battery terminal).
Any advice or pointers is gratefully received.
Old 01-Apr-2014, 21:51   #2
I take it that's the Weber carb model with the Digiplex ignition
Old 01-Apr-2014, 21:53   #3
Errmmmm....I know it definitely has Weber carbs
Old 01-Apr-2014, 23:18   #4
Sadly I have no experience of these early models, did you check if both plugs were sparking, if they are then I would be cleaning out the carb.
reg/rec needs a good earth for the battery to charge but if battery is already charged it should run
Old 02-Apr-2014, 19:48   #5
Thanks skidlids, guess I wont be going anywhere this weekend!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:23.
