Old 18-Apr-2006, 22:03   #1
gimpboy450 gimpboy450 is offline
gimpboy450's Avatar
Mood: crank it and bank it
Paddock stands and bobins
Right, I have had it up to here with these effing paddock stands last night went to change the front wheel putthe bike on a Harris universal front paddock stand, come back today and the bikes on its side??
Is there any better system for the front? ie bobins but not the ones that fit through the axle as thats no good if you want to take the tyre off!!
At the rear i have the R&G axle bobbins but there rubbish also cos you cant take the wheel out without removing the bobins! Whats everyone else using?
Old 18-Apr-2006, 22:28   #2
what age is your bike ie what swing arm?
Old 18-Apr-2006, 22:32   #3
clint 999R clint 999R is offline
clint 999R's Avatar
Mood: just love my slipper clutch
bit late now but you cant leave the bike on the front stand without it being on the rear stand as well it will move on the head stock and fall over as for the rear all the bikes ive ever owned have had the bobbins on the swinging arm apart from 996 which fits in axle but wheel comes off the other side
Old 18-Apr-2006, 22:45   #4
gimpboy450's Avatar
Its a 749 on a 2003, couldnt put it on the rear stand because i wanted to take the rear wheel off but couldnt because the bobbins run through the axle so left it on the front only.
So now until I get cups for the rear paddock stand i have put slabs under the side stand and slightly tilted it over on the stand by 2-3 degrees.
Old 19-Apr-2006, 00:03   #5
gimpboy450's Avatar
All i can say is very poor design by ducati, no real suprise there! Unlike Japy's which would have a threaded instert in the swing are for cotton reels, poooooooooooooooooorrrrrrrrrrrrr!!
Old 19-Apr-2006, 06:51   #6
Ah well ya see they do that so you have to spend another £100 or more on a DP 749 specific stand.
The 'proper' 749/999 stand has little rubber cups that fit under the chain adjusters.They do work very well.
The abba stand is good,but only lifts the back end up,so you will need to use your front stand for wheel removal.
Never use a front stand on its own,...no matter how well you think you have it chocked up.
On my '03 999,I used an old DP stand for the 851/888.I just swapped the hooks for some Motrax rubber cups.Worked for me.
[Edited on 19-4-2006 by KeefyB]
Old 19-Apr-2006, 09:40   #7
748rosso 748rosso is offline
Mood: C'MON YOU IRONS !
On my 03 749s,use a single sided paddock stand on the rear and the front, the stand which has the rubber pads on it.Both DP items.
Old 19-Apr-2006, 09:45   #8
khushy khushy is offline
khushy's Avatar
Sorry to hear that matey!
on my 999s I use . . .
a single sided rear 748/996 stand for when I am in a rush
a motrax rear stand with bobbins on the swinger
a 748/996 front DP stand that fits nicely underneath the fork bottoms
obviously it has the black 04+ swingarm, which I guess you dont.
khushy
