Old 04-Apr-2014, 10:09   #1
Bike to Bike Intercomms - Calling PJ?
Myself and a buddy fancy a B2B intercomm system for riding to WDW in July.
The choice is bewildering already but I was very impressed by the Interphone range at the Milan show - nothing to do with the stunning ladies on the stand, obviously
Ive got a basic outline already, Bluetooth headset to radio handset that I think Id prefer was handlebar button press-to-talk rather than VOX, as I dont want to hear my buddy swearing in Scottish behind me when I take a wrong turn
Suggestions / Experience, on radios very welcome.
Cheers - Frank
Old 11-Nov-2014, 12:18   #2
Stormchaser Stormchaser is offline
Bikes: ST4 & Firestorm - Sadly no more DDue Racer
Stormchaser's Avatar
Intercom
Did you get a B2B intercom in the end? I'm also now looking at getting a system as the wife passed her test and I need to tell her to slow down and wait for me! We're looking at Scala Rider but they sooo expensive!
Old 11-Nov-2014, 14:21   #3
Thumbs up
I bought a set of generic BlueTooth ("BT") intercoms off ebay for use during WDW and they were ... fantastic!
For a pair of headsets it cost £52 delivered. I went for a specific type/look and a better range (800m instead of 500m) set, as this was the sweet spot in price vs spec.
Although the set I have come with fixed mic booms, they fit easily into both my Arai Astro-R and Arai Tour-X. The fitting kit includes all sorts of options such as double-sided adhesive pads and a clamp kit for the side for the main unit. The speakers are velcro backed and fit fine on the helmet lining. I spent some timing running the cables behind the padding/liner to keep things tidy.
The BT unit has a power button, a "jog wheel" and a central button in the jog wheel. The power button turns it on and also connects to any other headsets that are paired. There is a one-time pairing process, but after this it "remembers" other headsets and "calls" them when you press this button once.
The jog wheel allows you to turn the volume up and down by rotating and holding the wheel.
If you pair the BT to your phone, you can also take calls and listen to music. When listening to music it will skip to the next/previous track by turning and releasing the wheel. The central button on the jog wheel starts and stops music playback. If you get an incoming call you can answer/hang up with the jog wheel button.
It's really easy to use and waterproof too. I can listen to music at any speed (tested over 100mph!) and I wear ear plugs as well. My iPhone has a separate volume setting when paired via BlueTooth, and I just had to turn that up to almost maximum, then use the BT volume control to turn it up/down.
For bike-to-bike they are ideal and you can easily hear the other person. Things would get a little garbled over long distances, and Andy had trouble hearing me over about 60mph but that may have just been either my microphone or his speaker settings as I could hear him fine! You simply press the button and it connects you to the other headset. Chat away - full duplex (as in you can both talk at the same time) - and when you're done press the button to disconnect.
To recharge you can either remove the unit from the helmet or leave it in place. You use the same socket that the mic/speakers plug into to charge it, so I just pull the mic/speakers lead and put the charging lead in overnight. I can get about 4-5 hours of music between charges.
In 26 years of riding I'd never felt the need for a headset, nor music on the go, but having ridden with this round Austria and Italy for WDW, I've kept it in the helmet and used it every day to listen to some background music on the daily commute.
Well worth the money!
I've attached a pic of my set on my Arai Astro-R. They are very similar to these ones on ebay: http://r.ebay.com/WZnXUn
Old 24-Nov-2014, 16:43   #4
Intercoms
Hi Antonye, thank you for such a comprehensive summary of this kit. I would not have expected something for that price to be any good but I am convinced and will order a pair and let you know how I get on. Much cheaper than the Scala/Interfone products and seems just as good other than not having the vox capability, but i'm sure that won't be an issue.
Old 24-Nov-2014, 20:43   #5
My friend Andy had a Scala so the option was there to just buy a single unit to connect to his, but a pair of these BT headsets still worked out cheaper!
I'm not sure how much better other systems are, but they would certainly have to do really well to beat these cheapies.
Old 20-Mar-2015, 08:17   #6
Looking once more!
For our trip later this year...
Ant's Ebay link above seems to have expired but, I found these 1000m units after a quick search:
http://www.ebay.co.uk/itm/2x-BT-Bluetooth-Intercom-Headset-1000m-Motorcycle-Motorbike-Helmet-Interphone-/351344651856?pt=LH_DefaultDomain_3&hash=item51cdc5 ee50
Recommendations still welcome.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:51.
