Old 19-Apr-2006, 10:14   #1
GlennG GlennG is offline
Mood: accepting the inevitable
620 Sport Forks required ASAP
Well it now appears that my Cadwell prang not only bent my discs, but also tweaked my lower fork caliper mount brackets on both forks and the front wheel spindle!
You see I fitted replacement 916? discs to the front wheel and it spins freely and discs are straight/fine without calipers fitted, but when the calipers are fitted then the wheel is clamped by the brakes. Both calipers do not appear to be hanging 'straight' ie slightly off the vertical - looking either side of the discs when viewing the gap between disc and caliper is different, not only from side to side but also top to bottom. The front spindle also appears to be tweaked as well!
So I'm on the hunt for a set of USD 620 Sport front forks and front wheel spindle asap.
I'm desperate as I need them for Brands this Sunday
Willing to travel to collect and pay a fair price.
Glenn
Old 19-Apr-2006, 15:56   #2
Well it looks like I'm sorted for some forks and borrowing a front spindle (thanks to twpd).
I should get them Friday, hopefully calipers will then line up correctly with the discs.
Ta
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:22.
