Old 20-Apr-2006, 16:15   #1
weeveetwin's Avatar
Anyone translate this..? (French to English)
Hi guys
I've a Dyno Chart print-out which came with the bike I've just imported. However, it's in French, so I'm having to guess a little at what it means. The columns are headed:
*Proue cv*
*ECETrq CNm*
*puiss cv*
*Lambda Ratio*
*Pvi/re cv*
*Pro/re cv*
Anyone help with its translation? (The free translation sites don't put these abbreviations into the context of an engine's output, so aren't much help!)
I've a receipt too, which says: réglage soupapes contrôle divers jeux fonctionnement
joint carter embrayage
passages banc
I think it's something to do with the valves/clutch etc. But what exactly? (Come on Phill911, where are you..?)
Steve
Old 20-Apr-2006, 16:31   #2
phil_h phil_h is offline
phil_h's Avatar
Originally posted by weeveetwin
Hi guys
*Proue cv* = wheel hp
*ECETrq CNm* = torque
*puiss cv* = hp
*Lambda Ratio* = co/o2 ratio
*Pvi/re cv* (more about hp)
*Pro/re cv* (even more about hp)
passages banc
Steve
CNm is Newton-metres(hundreds) ie equiv to ft/lbs
cv = cheval-vitesse I think (horse-speed)
Old 20-Apr-2006, 17:24   #3
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
"réglage soupapes contrôle divers jeux fonctionnement"
Something along the lines of "valve adjustment and check operation of various controls "
I fink....... :P
Old 20-Apr-2006, 17:45   #4
lamda is a gas measurement to do with your fuelling/exhaust, obviously used on every dyno.
Old 20-Apr-2006, 17:52   #5
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
sorry, that was not in French
Old 20-Apr-2006, 19:31   #6
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
How would you know.
Old 20-Apr-2006, 19:33   #7
domski's Avatar
Yeah, bloody Londoners
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:17.
