Old 21-Apr-2006, 09:49   #1
phil_h phil_h is offline
phil_h's Avatar
851SP Tank question
Should there be a rubber seal between the (alloy) tank and the big circular filler assembly ?
(similar to old SS tank)
Old 21-Apr-2006, 12:12   #2
851neil 851neil is offline
Mood: need a bike...
yes there should be a seal there.
cheers
Neil
Old 23-Apr-2006, 20:25   #3
CL955 CL955 is offline
Possibly
Not wishing to contradict Neil, it depends. There was a transition period around '91 where the factory moved from the aircraft style filler and the hinged lockable job. The only seal on these was a green o-ring which never did a complete job, and needs gunking up with lots of sealant to prevent seeping.
On mine, I tried fitting the additional rubber ring ring 'twixt cap and tank and it just would not work. I think that later cap assemblies were modified to allow the black seal as well as the o-ring.
charles
Old 24-Apr-2006, 03:33   #4
Ducman851 Ducman851 is offline
Mood: Just Ducky
charles
My 1990 851 w/above mentioned aircraft style cap has the rubber seal around the outter edge of the assembly. Its also on the microfiche I have.
Charles, I believe yours is missing.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:23.
