Old 21-Apr-2006, 20:41   #1
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Redex: How Much to Use in 3/4 of a Tank?
You may have seen my other "Won't Rev Past 7000rpm" post, which the consensus of opinion seems to be is due to fuel starvation due to a blocked filter.
I have some Redex lying about somewhere.
Just wondering if this might help a little, until I can get round to fitting the new filter.
If so, how much should I use?
Old 21-Apr-2006, 20:43   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Errrrrr...no. I wouldn't use it at all tbh. Snake oil - try the things that were suggested first.
Old 21-Apr-2006, 20:44   #3
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
Sorry my friend but I wouldnt touch the stuff.
Stick it in your old Ford but not your Duke, thats just my opinion.
Old 21-Apr-2006, 20:59   #4
Change the filter. If you don't then the next thing to fail will be the regulator.
Old 21-Apr-2006, 21:05   #5
zhed44's Avatar
Mood: YELLOW!!!
The filter is on its way, but I'm having to keep using the bike in the meantime as I only just discovered 3 days ago that my Bandit's MOT and tax ran out in March
As soon as it arrives, it will be fitted.
On that point, is there anything I should be aware of when changing the filter (apart from put your fag out)? Is it just as described in Haynes, or is there anything they've missed out?
Old 22-Apr-2006, 01:45   #6
Bungi Bungi is offline
its a pretty straight forward job, can be a bit tricky sometimes getting the pump assembly back into the tank, what with the sealing ring jumping out of place, i use some vaselene and if it puts up a fight run a cable tie round the circumferance to keep it in place while it slots in, then remove the tie of course
Old 22-Apr-2006, 11:33   #7
raykay748R raykay748R is offline
Bikes: 748R, ZXR 400
raykay748R's Avatar
Mood: Glad to be back down south.
Yeah ditto bungi's remarks, careful with the seal putting it in, if you trap it then it'll split, and the first you'll know of it is when you come to re-fill the tank, cos your feet will suddenly be all wet and your airbox full of fuel. Don't ask me how I know please!! It's embarrassing and I'm a professional. Don't know what at sometimes!!!
Old 22-Apr-2006, 14:38   #8
zhed44's Avatar
Mood: YELLOW!!!
Sorry to be a bit of a numpty, but do i need to drain the tank?
Old 22-Apr-2006, 20:22   #9
raykay748R's Avatar
When you remove the tank you'll notice the drain plug, allen key needed here. Don't worry the tank is connected to the rest of the fuel system via 2 self sealing QR couplings.
Old 22-Apr-2006, 21:12   #10
rxtim rxtim is offline
You may want to get the o-rings that seal the couplings though.
And the one for the fuel pump assembly.
Petrol dripping down a hot engine is a bit worrying!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:17.
