Iv had starting problems for a while but just put up with them.
I think I have traced the problem to a badly corroded starter motor terminal but I cannot remove the nut. so the only answer is to remove the starter motor but to do this I need to remove the left hand engine caesing to acces 2 of the starter motor bolts.
Q: Do I need to drain the oil?
Q: Will I need to bleed the clutch when refiting?
Q: Is there a quick solution?
I have a Haynes manual but this info isnt in it.
