Old 23-Apr-2006, 19:09   #1
Rectifier / Regulator remounting idea\'s
Next on the menu, I have a replacement for my regulator already, I'm going to change it anyway as I figure 13 years is pretty much a warning.
I remember reading ages ago about someone in the USA mounting it at the rear of the bike, not so sure about that given UK weather but, for the SS I did think about mounting it in the 'cockpit' area, under the headlight somehow, so that it gets an airflow from the ducts in the fairing.
Comments please???
Also I did see mention that the connections are also a weak point and can be modified / improved - cant find that webpage either
Cheers - Frank
[Edited on 23-4-2006 by Iconic944ss]
Old 23-Apr-2006, 19:35   #2
Aye,it was one of Shazaams posts.He fitted it inside the rear mudguard.
Just remember to connect the 'earthing' tag and fit some sort of heat sink.
Old 23-Apr-2006, 20:04   #3
Harv748 Harv748 is offline
Harv748's Avatar
This is the one:
http://www.ducatisportingclub.com/xm...d.php?tid=2042
As for connectors, having just redone all mine after having charging problems, I have opted for some 40A rated bullet connectors from Maplins, but rather than just crimping them onto the thicker guage wire I have also fitted from the Alternator, I have removed the plastic coating that comes with them, and soldered them on, then covered in heat shrink.
Tidy job.
[Edited on 23-4-2006 by Harv748]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:34.
