Old 24-Apr-2006, 14:30   #1
Abbott Abbott is offline
Bikes: 916 BP
Mood: Marvellous
916 Cush Drives
Has anyone got any advice / techniques for removing cush drives from my standard sprocketed 916 (96/97) and inserting them into a new Renthal carrier / sprocket set please.
Any issues, good techniques, gotcha's???
Dave
Old 26-Apr-2006, 10:50   #2
Pete A Pete A is offline
Pete A's Avatar
Hi Dave,
You shouldn't have any problems removing the cush drives, you'll need a 14mm allen key, or better a 14mm hex. bit socket to hold them whilst you're undoing them. They are not particularly tight in the original sprocket, or the carrier.
If you do have to drift the old ones out if they've corroded in, make sure to use a piece of tube or (Haynes special!) suitable sized socket (ouch!) rather than hitting straight on the stud, so that you don't risk breaking the rubber bond.
Whilst you're at it why not fit new ones, they're not particularly expensive?
Hope this helps.
Regards, Pete
