Old 25-Apr-2006, 21:51   #1
boski69 boski69 is offline
boski69's Avatar
Mood: Here comes the summer!!!!!!!!!!!!!!!!!!!
900 Showa forks
Just rebuilt the ss after a shunt last year. One seal was leaking so stripped em down and re fit seals. re filled with fork oil from Hein Gerick. I dont know if this was a mistake cause I know it says in the manual to use Showa fork oil. The front end bounces around so much that I have had to back off the preload and damping to minimum just to stay on the thing. HELP!!! Is the oil type really that critical??
Brian.
Old 25-Apr-2006, 22:24   #2
CK CK is offline
depends on the quantity (measure the height of the oil) and the weight of the oil (usually 7.5 for road ducati's so I am told by AK)
Old 26-Apr-2006, 00:25   #3
Best write up on Showa rebuild I've seen yet:
http://www.motoreva.com/showa/showa.html
He recommends 300cc of 5W oil.
Frank
Old 27-Apr-2006, 18:29   #4
boski69's Avatar
Thanx for the replies. As I put 440cc in each leg I think I will drain them down to 300 and see how it goes.
Cheers Brian.
Old 28-Apr-2006, 09:34   #5
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
Cheers Brian.
Ignore the quantity, the important thing is the oil level - it should be 108mm from the top of the fork with spring and spacer out. A 5wt oil is best.
Old 29-Apr-2006, 15:31   #6
boski69's Avatar
Thanks Derek, I'm beginning to understand how these things work.
Cheers, Brian.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:01.
